PLACING SAME 3D VIEW IN MULTIPLE SHEETS
2 REPLIES 2
Mohamed_Arshad
980 Views, 2 Replies
HII Geniuses,
     Anybody knows hoe to place same 3D view in multiple sheets. Or i need to create multiple duplicate views.
Thanks & Regards,
Mohamed Arshad K
2 REPLIES 2
hmunsell
in reply to: Mohamed_Arshad
Right click on the 3D view and select Duplicate View > Duplicate or Duplicate with detail.
  • Duplicate will make a copy with no annotation
  • Duplicate with Detail will make a copy will any annotation added to the view.
Howard Munsell
No you can't.
You only can do has hmunsell said.
Big BUT : you can't duplicate 3D views as dependent, so if later you change the view it will not change the other views.
Forma Design Contest
