The rooms on all floors appear to have no issues but for some reason on the basement and roof levels. All the rooms appear smaller than the actual room and don't reach the walls, I checked the room schedule it says that it is not enclosed
I'm not sure how to spot the cause of this error...I managed to find some unjoined walls and joined them but it's a huge layout with 220 rooms!
Any ideas?
Solved by RDAOU. Go to Solution.
@Anonymous
If it's all over the floor (all rooms) it has most likely to do with something which affects the whole floor or some roombounding element which is repetative in all rooms causing them all to become "not enclosed" ie: they shrink on the plan/layout.
If the above doesn't work, give feedback...will think of something else
