Pipe Break Line question, help or comment appreciated,
Message 1 of 16
Hello, I have asked this question over on MEP but still no answer,
I am looking for a Pipe Break Line a round one as we are using it for piping,
We need the lineweight to be editable with the differant pipes it would be placed on,
Now I have created a family for this, but what I would need an answer to is a better way to insert the family, we are looking for a way like you would insert it in AutoCAD,
You would be picking the start and end point for the size of the pipe, we were wondering about this becuase we need this family for many pipes, for the dfferant sizes, and angles.
Beign able to insert this like in AutoCAD would save time.
Could it be something as simple as changing the snaps or making the family in genaral.
Thnak you, to anyone with help, or comments.
Replies (15)
Message 2 of 16
Unless you can find a way to make curved lines change size by clicking a grip and dragging like you would in AutoCAD, then I think your best solution is your family with multiple types for each size.
Good luck.
SY
Message 3 of 16
RDAOU
@Anonymous
  1. When you say you model a family already, what did you model exactly and using which template? We shouldn't need to discuss something you already tried 🙂
  2. Can you attach your modeled family so one may check if you can work further on that and develop it intead of starting somethng new?
  3. Did you try a similar approcah to the fire escape route family? using a line based family which allows for 2 pick points placement start/end ...
Message 4 of 16
Only thing we are looking for is the insertion part.
If it can auto size to whatever pipe we need it on or have it as a pick two points.
Thank You.
Message 5 of 16
To further clarify, we can change the size by the dimensions on the left but again we are looking for a AutoCAD or auto size way.
Thank You.
Message 6 of 16
Matt__W
Like this??  Attached family is 2014.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 7 of 16
Thank You so much!!
Message 8 of 16
Matt__W
You're welcome. You were on the right track. I just remade the family using the DETAIL ITEM LINE BASED family template. The only thing you need to keep in mind is which direction you draw it because it may come in backwards. Although (thinking out loud) you could probably simply add a flip control to it.
Matt Wunch
Twitter | LinkedIn
Message 9 of 16
Matt__W
One other thing... You'll need to modify the line styles to suit your standards.
Matt Wunch
Twitter | LinkedIn
Message 10 of 16
Matt__W
I added the flip control to this one. I couldn't leave well enough alone.  🙂
Matt Wunch
Twitter | LinkedIn
Message 11 of 16
abe.torres
Hi Matt,
I appreciate the input on this. I assume this is only for smaller diameter pipes. When I use it on large diameter pipes it loses the oval shape and it looks more like two circles.
Message 12 of 16
Thank you so much
Message 13 of 16
rbarbosa8DQGJ
Hi, can you tell how break the tube above without hiding the tube below?
Message 14 of 16
Matt__W
You can't because there's no way to layer a masking region. In other words, you can't have a family with multiple masking regions, one at say 12" and the other at 24" to hide objects at varying elevations. I think the best you can do is create a family similar to one attached and also show the pipe below.
Or mask the entire gap and add lines and a parameter that represents the pipe below.
I've attached both families.
Matt Wunch
Twitter | LinkedIn
Message 15 of 16
rbarbosa8DQGJ
Message 16 of 16
rbarbosa8DQGJ
