Hi all,
I would like to create an SVP family that consists of an extruded void (150mm diameter x depth parameter) and a 2D symbol with 110mm diameter pipe and 150mm diameter dashed line to indicate the hole.
I can do the first bit easily, but when I add 2D symbols in the ref plan view, I cannot add in a filled region. Upon googling this, I understand that I need to nest an annotation symbol to do this. If this is right ?
When I create an generic annotation, this scales with the view scale, which I do not want.
Could you please advise the correct way to do this ? Should I be using detail componants for this ? I also need to use this family to set out from, so I need dimensions to recognise for witness lines.
Thanks in advance.
