Adding an Extension line
Hello!
I'm trying to add an extension line to my View Title Type.  As you can see in the image the current extension line runs through the center and I would like to add another one that would run on top of the 'View Name'
I've noticed that when I go to edit the family the horizontal reference line is what the extension line is set on but I'm not sure how it knows to do that.
Thank you
I'm pretty certain that the extension line is hard coded into revit. I don't believe you can add a second one that will give you the same grips but perhaps someone else knows for certain. If nothing else you could draw in your own line and perhaps control its length with a parameter?
