- Mute
- Permalink
- Report
Hello, new to Revit. Have an easy question I can't find answered anywhere online.
I set up a model to have an "Existing" and a "New" Phase.
I then applied a colored surface pattern graphic override to the "New" phase status in Manage > Phasing > Phases > Graphic Overrides. It looks like this:
I then set the filter options for the phase filter "New + Existing" to "Overridden" for New Phases in Manage > Phasing > Phases > Phase Filters. That screen:
Now, in every view that I set to "New + Existing", the New Construction phase work appears in blue, which is perfect. It works in floorplans, sections, axons, and elevations.
My only problem is that the phase filter override is not applying to any of my roof plans, of which there are 4. It's only NOT applying in these roof plans. Does anyone have any idea why they're not applying in roofplans? Does it have something todo with View Range?
Thanks in advance.
