DWG incomplete in Autodesk Online Viewer
3 ANTWORTEN 3
Nachricht 1 von 4
taiane.bohrer
198 Aufrufe, 3 Antworten
I am uploading a model to Autodesk Online Viewer, but the autocad linked to the model is not showing completelly.
See attached 1 screenshot from the Revit Model, and 1 screenshot from the online viewer.
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: taiane.bohrer
If you look from the bottom of that model, does the 2d drawing show up? I notice Autodesk online viewer shows one side of the face while hide the opposite side. So when you see missing object, it is relate this shortcoming. However this post does help if you want to make the viewer show up both face.
https://forums.autodesk.com/t5/revit-architecture-forum/autodesk-viewer-missing-surface/td-p/8200104
Nachricht 3 von 4
taiane.bohrer
als Antwort auf: syman2000
Thank you.
I try to add the code, but it didnt work.
My problem is not with faces, but with lines.
Nachricht 4 von 4
syman2000
You can try export Revit to Naviswork. Then upload the Naviswork model to Autodesk online viewer. I find Naviswork resolved a lot of the missing faces.
