phasing - elements in projection showing darker than cut elements
18 REPLIES 18
Message 1 of 19
amy
1485 Views, 18 Replies
I have existing elements and when cut a section the elements back in elevation have a hatch pattern darker than the elements being cut. How do I fix this?
Even with existing elements, the item being cut should have a darker diagonal hatch thru it then the element back in elevation.
in screen shot 1 is cut thru existing grade beam and two is existing grade beam beyond.
18 REPLIES 18
Message 2 of 19
in reply to: amy
Look into the Phase Graphic Overrides setting for colors of surface and cut patterns for Existing elements.
Message 3 of 19
in reply to: amy
Phase Filter set to Show Complete in Elevation?
Message 4 of 19
amy
in reply to: barthbradley
Show Previous and New
Message 5 of 19
in reply to: amy
If you want to show everything as Complete then change the View to Show Complete. If you want to differentiate new and existing then look in to phase Graphic Overrides and modify the Existing row.
Message 6 of 19
amy
in reply to: ToanDN
Even if I make the cut the same shaded line style 192/192/192 as the
projection pattern, the cut is lighter than the projection pattern.
Message 7 of 19
amy
in reply to: ToanDN
Yes I had changed the phase filters and graphic overrides for existing and
still having the same problem.
Message 8 of 19
in reply to: amy
Check what Line Weight #1 is for the scale of your view..
Message 9 of 19
in reply to: amy
Well, there's the reason. View is differentiating Previous (Existing) from New (New Construction).   If you want them displayed the same, then Show Complete
Message 10 of 19
amy
I don't want them to show the same as the new portions of building. New
should not have a hatch thru it which it does not. The only problem I have
is with the existing. The stuff back in elevation should have a lighter
hatch then the stuff being cut thru.
Message 11 of 19
Christea30
in reply to: amy
Has anyone found a solution?  I'm running into a similar situation.  All the graphics are the same, but the hatch pattern for projected demolition is heavy.Demolition Hatch.png
Message 12 of 19
amy
in reply to: Christea30
I have yet to find a solution using phasing overrides.
Instead of using phase graphic overrides I wrote a Filter rule based on Phase Created and Existing.
Then in your view templates turn on the filter and change the lines and patterns for projection and cut to lighter line weights and a light black hatch. If you make a view template from this filter it can be applied to views as needed
Message 13 of 19
post a picture of your phase filters.
 which phase is your view in?
what phase filter do you have applied.?
hard to really help without seeing the entire picture.
Message 14 of 19
Christea30
in reply to: amy
I can't get that to work either.  The only thing that changes the thickness of a Projected Hatch Pattern is to change the Projected Line Weight in the main Object Styles. This changes everything regardless of phase or filter. The thickness of the hatch pattern is directly linked to the thickness of the Object Style Projected Line Weight. When I apply a filter of any type and adjust the line weight of Projected elements it does nothing, I suspect this is why the phasing changes do nothing to the line weight.
Message 15 of 19
amy
in reply to: amy
I can not get the filter to work either.
Huge revit problem and hoping this is fixed asap. Would love to be able to pick the pattern line weight as well as the object line weight.
Message 16 of 19
in reply to: amy
Post your file.
Message 17 of 19
amy
Here's just a basic example. But happens in every project where there is existing.
Message 18 of 19
in reply to: amy
Ah! I see what you are talking about now! The Projection Surface Hatch Pattern Line Weight is using #2's Weight. Same as Hatch Patterns in RCP Views.
Message 19 of 19
in reply to: amy
Forma Design Contest
