phase existing graphics overrides
Why does walls and floors on phase existing looks like they are Coarse when I aply phase graphic overrides?
Id like to maintain all the layers and the hatch pattern, and just modify the color by graphic override.
Is it possible?
Then do not override Cut pattern, only Color.
Thats what I did, but like I said, walls and floors are in Corse mode for some reason (I checked VG and thats not it...), so the pattern is not displayed. Only when I change the phase material I can control pattern, but it changes all wall and floors at the same time.
Thanks for answering!
David_W_Koch
WIth the Fill Pattern override to No Override, the Material set for the Phase Status will be expressed.  If you want to see the Fill Pattern ByCategory, then delete the Material assigned to the Phase Status.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Can you post a screenshot of your floor plan showing both existing and new
walls?
-Toan
Yes, it worked!
Thank you!
