Phase created not showing in View Filters
dbecerra8XM6N
Message 1 of 9
dbecerra8XM6N
Hi! I'm trying to colour-code some walls using the Phase they're created. However, it is not showing in the drop-down list for Walls. Am I missing something?
Replies (8)
Message 2 of 9
Strange.
Following...
Message 3 of 9
Wait a minute. What version are you on?  The ability to filter by phase was not always a thing.
Message 4 of 9
dbecerra8XM6N
Revit 2021.1.7
Message 5 of 9
Well, obviously you don't have it. It must have been added in 2022.
...yep. not there in 2021.
Message 6 of 9
dbecerra8XM6N
Bummer, maybe we will use it for another project. I guess we will use an additional parameter
Thanks for your help!
Message 7 of 9
chubbard
You could always use Phase Filters with a specific override on different phases. Not as useful but might work depending on what you are trying to show
Message 8 of 9
michael.coviello
Autodesk Support
Autodesk Support
Hello @dbecerra8XM6N
@barthbradley mentioned, this has been added in Revit 2022.
Do the steps in this article help for you in earlier versions?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-create-a-Vi...
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Message 9 of 9
dbecerra8XM6N
Yes, thanks! we used a similar solution using filters.
