suddenly my model looks like this (pls see Screenshot in the Attachment, Re1.jpg). The graphic setting is fine, i didn't change anything (Re2.jpg). It happens only when i click the 3d view (the small haus icon on the top, Re3), but all the saved 3d views in the browser look good.
Does anyone know the solution?
Thank you very much!
Bests,
Han
Gelöst! Gehe zur Lösung
Gelöst von XiaolinHan. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Probably a corrupted View. Delete View and recreate. If it's the Default 3D, Delete it and press the House Icon Button on the QAT to create a new one.
See if disabling Hardware Acceleration resolves.
Hardware Acceleration | Revit 2020 | Autodesk Knowledge Network
Hi, barthbradley
thank you so much! Your link helped! I found through your Link the Solution here:
Solved: Re: Weird semi-wireframe view - Autodesk Community - Revit Products
and tried the Answer von RDAOU and then it works!
Have a nice day.
Bests,
Xiaolin Han
I copied the corrupted view and put it in the Browser under my name (see Re5.jpg) and then created a new one, this one went automatically to the views with the question marks, and then the magic happened.
I don't know why, but it becomes normal now!
Best regards,
Xiaolin Han
