Hi all, is there a way to measure and schedule the external perimeter (overall length) of a building. And measure and display lengths of kitchen cupboards etc. as per the screenshot?
I'm using RevitLt
Solved by ToanDN. Go to Solution.
There isn't a one off parameter which applies to all. There are different ways to extract the perimeter/Length of elements. Example:
Ok, that could be an option. However with the kitchen cupboards and pantry I only need the length. If I draw a property line, I'll get the perimeter of the cupboard which wouldn't be accurate. The screenshot I showed was drawn in archicad so I'm not sure if they have a different system.
A property line needs not to be a closed loop. It can be a single segment, a, open polyline, or multiple unconnected segments.
Ignore it of course since you need the lengths, not areas. See example project 2022.
