Hi
I have an example here of 2 furnishings. On one side the instance is under the plan section, on the other the instance is above plan section. The problem here is the lineweight. the thickness of the wall is affected by the element.
how to make sure that the thickness of the lines of the partition remain intact?
Solved by ToanDN. Go to Solution.
If you don't like to change the family, you could try this method for quickly overriding the line of the wall:
- Use Linework (LW) and choose a linestyle with same thickness) but it's view dependant.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
yes i know about LW, but i cannot ask users to LW thousands of elements.
@Yien_Chao wrote:
it could work, but if there a way to keep the plain rectangle?
Several ways:
- Override the category to 100% transparent
- Add a symbolic line (or a masking region boundary line) under a subcategory in the family and match the subcategory line weight with the wall cut line weight in the project
- Place the family slightly away from the wall
