Perforated Metallic Panel
giul0345
giul0345
I have to create this perforated metallic panel in revit, can anyone help me to find a solution? I already tryed to make a pattern family and the place it on top of curtain wall but the result is not that good.
this is what I have to createthis is what I have to createthis is what I didthis is what I did
RDAOU
@giul0345
Unless you are doing this for learning purposes, you should simply use a material with cutout similar to what is discussed on the following forum post. Parametric stuff is always fun to do but it can be a waste of time if one can simply achieve the same output in a few seconds rather than spending a lot more on a perforated panel
Solved: Need some metallic perforated panels - Autodesk Community
Solved: Perforated Metal Screens - Autodesk Community
You can also download Revit file from this post and notice difference in performance between a parametric perforated panel and a curtain wall panel with perforated material applied to it. See attached 2022 Revit with both panels.
Solved: Applying a pattern on a panel - Autodesk Community
