PDF printing from Revit missing
8 REPLIES 8
Message 1 of 9
hubbardFJXGT
561 Views, 8 Replies
In this file a number of views are not exporting to PDF correctly. Linework is being dropped from sections where items are being cut. I suspect this is a corrupt view, but it is multiple so before I replace all, wanted to see if there was a better solution
Cut looks fine in Revit and ACC, but lines disappear in PDF. Even if I draw a detail line over the model that line still does not show in PDF.
Tried multiple PDF printers, Vector/Raster all the same
In the attached view its always the same line. In others it has been multiple lines and often different ones.
8 REPLIES 8
Message 2 of 9
in reply to: hubbardFJXGT
What am I looking for/comparing in these JPEGs?  Maybe you can highlight it.  I'm no go in treasure hunts. 😉
Message 3 of 9
hubbardFJXGT
Highlighted
Message 4 of 9
Does toggling Region Edges Mask Coincident Lines checkbox under Printer Setup have any affect?
Message 5 of 9
hubbardFJXGT
That did it for one view (the one I screenshotted, but not the others.)
When I draw a new section in nearly the same location, it works for all of them, Mask checked or not. No difference between Mask Coincident or not.
Not very consistent behavior
Message 6 of 9
Print to PDF or Export to PDF?
Message 7 of 9
hubbardFJXGT
Both. Tried multiple PDF printers as well. Seems like a view issue.
Message 8 of 9
I am surprised Revit native Export to PDF has this issue.  I can't comment on any PDF printers because I stopped using them.  Have you tried DiRoots One Prosheet PDF export?
Message 9 of 9
hubbardFJXGT
Nope PDF Export is the standard we are using.
I do not have DiRoots PDF, But tried BB, CTC and Adobe Pro. All the same results.
Forma Design Contest
