Roofs are not the same height
20 ANTWORTEN 20
GELÖST
Nachricht 1 von 21
tyrrkuuuzi
1656 Aufrufe, 20 Antworten
I am doing a plan and building the roof and they are not the same height, anyone know what the what is happening?
The front, the garage and the main roof and the shed roof for the porch are not the same height.
Tags (3)
Beschriftungen (1)
  • Roof
20 ANTWORTEN 20
Nachricht 2 von 21
als Antwort auf: tyrrkuuuzi
Because they have the same slope so bigger roofs shall be higher than smaller roofs.  If you want to match height then stretch the arrow of the shorter roof to match the peak of the taller roof (may need to draw a ref plane so it is precise).
Nachricht 3 von 21
Is your question why the eaves do not align even though all the Roofs are hosted to the same Level with the same Base Offset From Level?  If so, it probably has to do with the Rafter or Truss setting under Roof Instance Properties. If you used Pick Walls to sketch your Roof boundary, you'll have this setting.  Check it out. If you have it, play around with it and you'll see what it does.
Help | Roof Instance Properties | Autodesk
Nachricht 4 von 21
tyrrkuuuzi
als Antwort auf: ToanDN
I will have to try this, I need to see if I can figure that out
Nachricht 5 von 21
tyrrkuuuzi
Okay maybe I did not explain it, I have a better picture in 3D
See how the two different gables and the porch roof are not the same height? do I just do an align thing with it?
Nachricht 6 von 21
Rafter or Truss?
Do the Roofs originate from the same Level and have the same Offset from Level?
Edit Roof Sketch and select the line representing that offset eave and look at its Properties. Is there an Offset from Roof Base for that one line?
Nachricht 7 von 21
tyrrkuuuzi
als Antwort auf: barthbradley
Like I do not understand why they are not the same hight
Nachricht 8 von 21
Did you read my Message 6 reply? How about my reply before that?
Nachricht 9 von 21
tyrrkuuuzi
No offsets, in either place and yes set at the same level
Nachricht 10 von 21
Post the rvt file here.
Nachricht 11 von 21
tyrrkuuuzi
Okay I was messing around it is the the different slopes making the roofs not match up (which I do not get) but how do I fix that? change the roof depth or something?
Nachricht 12 von 21
tyrrkuuuzi
Here it is, excuse the roughness of it (I just started and still learning lol)
Nachricht 13 von 21
Nachricht 14 von 21
Did you draw the roofs using Pick Walls?
Nachricht 15 von 21
tyrrkuuuzi
Yes i used pick wall, okay see this screen shot.
Both roofs are set to an 8inch thickness
Nachricht 16 von 21
tyrrkuuuzi
Nachricht 17 von 21
mhiserZFHXS
The 10" dimension isn't the thickness of the roof. The thickness is a line perpendicular to the face of the roof. That is the vertical edge, which is not the same.
Nachricht 18 von 21
tyrrkuuuzi
als Antwort auf: mhiserZFHXS
Okay thank you!
Nachricht 19 von 21
A Fascia Depth of 10-inches doesn't work on an 8-inch thick, 4/12 sloped roof.
...works fine and dandy on an 8-inch thick, 13/12 sloped roof.
Nachricht 20 von 21
FWIW: If you want a 10-inch Fascia Depth on the 4/12 sloped roof, then the roof needs to be greater than 9 125/256-inches thick.
