PAT Tile moving diagonally?
3 REPLIES 3
josh.hafel
1172 Views, 3 Replies
I wrote out a pat file and I cannot figure out why it is so messed up. The vertical lines are exactly as I wrote them, but the horizontal lines are moving diagonally across the hatch at 69.44 degrees! If anyone can give a suggestion it would be much appreciated.
;%UNITS=INCH
;%VERSION=3.0
*RR FLOOR TILE , Half
;%TYPE=MODEL
90, 0, 0, 0, 36
90, 6, 0, 0, 36
90, 12, 0, 0, 36
90, 24, 0, 0, 36
0, 0, 0, 90, 48, 6, -6, 12, -12
0, 6, 24, 90, 48, 6, -12, 12, -6
Tags (2)
3 REPLIES 3
Pattycake_Kyle
in reply to: josh.hafel
Your shift value of "90" doesn't make sense in this case. Change that 4th value in the last two lines to "0" and its probably what you want? Otherwise post a dimensioned image of what you are looking for and I can help better.
Pattycake color codes lines to help de-bug for cases like this. Click this link below and change those values to zero to see how it lines up nicer.
https://pattycake.io/pat/8GGGMy752oB
As your values state:
 After changing 4th value in last two lines to "0"
Hope this helps!
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
josh.hafel
in reply to: Pattycake_Kyle
This resolved my issue, but on a much more important note, pattycake is beautiful! Where has this been all of my life 😭
Pattycake_Kyle
Thanks!!!! So great to hear that we could help and you're enjoying the platform. We've been in development for 18+ months now and are super excited to be releasing version 01 very soon. Thank you again for the kind words, and while the beta is still up... use code: sprinkles19 to sign up 🙂
And as a teaser to our version 01 (with tons of new features) check here: Pattycake Version 01 Teaser
Peter and Kyle from PattycakePeter and Kyle from Pattycake
www.pattycake.io
Forma Design Contest
