I wrote out a pat file and I cannot figure out why it is so messed up. The vertical lines are exactly as I wrote them, but the horizontal lines are moving diagonally across the hatch at 69.44 degrees! If anyone can give a suggestion it would be much appreciated.
;%UNITS=INCH
;%VERSION=3.0
*RR FLOOR TILE , Half
;%TYPE=MODEL
90, 0, 0, 0, 36
90, 6, 0, 0, 36
90, 12, 0, 0, 36
90, 24, 0, 0, 36
0, 0, 0, 90, 48, 6, -6, 12, -12
0, 6, 24, 90, 48, 6, -12, 12, -6
Solved by Pattycake_Kyle. Go to Solution.
Your shift value of "90" doesn't make sense in this case. Change that 4th value in the last two lines to "0" and its probably what you want? Otherwise post a dimensioned image of what you are looking for and I can help better.
Pattycake color codes lines to help de-bug for cases like this. Click this link below and change those values to zero to see how it lines up nicer.
https://pattycake.io/pat/8GGGMy752oB
As your values state:
After changing 4th value in last two lines to "0"
Hope this helps!
This resolved my issue, but on a much more important note, pattycake is beautiful! Where has this been all of my life 😭
Thanks!!!! So great to hear that we could help and you're enjoying the platform. We've been in development for 18+ months now and are super excited to be releasing version 01 very soon. Thank you again for the kind words, and while the beta is still up... use code: sprinkles19 to sign up 🙂
And as a teaser to our version 01 (with tons of new features) check here: Pattycake Version 01 Teaser
