.pat files
.pat files
.pat files
Hi everyone
I need to either import or create a .pat file for a Revit model. The .pat file needs to be a gradient to show a circular column in elevation. My process would be to edit the surface pattern, and then use the new .pat file.
How do I create a .pat file, in either Revit or AutoCAD?
Regards
Lauren
www.TechRoom.bg
Here and Here are official solutions by Autodesk knowledge base.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Keith_Wilkinson
My suggestion for this is to create your pattern module within CAD then use this progam (free) to generate the hatch itself using the start and end coordinates for each line in your pattern. It's pretty simple and works well.  remember to define if you are doing a drafting or a model pattern.
Revit Hatch Builder
HTH
K.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
I don't believe you can have gradient fill patterns in Revit.
If you are not satisfy with a shaded view of the round columns, you may need to insert a gradient image and overlay on your elevation.
Keith_Wilkinson
Missed the bit about gradients... yeah, that's not going to work with a .pat file.  ;o)
Maimonides
Attached is a .pat file with a bunch of patterns.
Michael P. Rybin = ۩ = Vernacular, Biomimicry, Gestalt, Net-Positive, Cradle-to-Cradle!
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Thank you for the help, and the .pat files! Not quite the solution I was going for, but those are great!
Regards
Lauren
