Parts of wall disappear in 3D when shadows added
stephen.melhuish
Message 1 of 12
stephen.melhuish
I have a Revit model that has a thin cement wall added over the top of an existing brick wall. The existing brick wall is in the Existing Phase and the Render is in the New Construction Phase.
When i view the model in Perspective it is ok UNTIL I turn on the Sun (Graphic Display Options: Lighting), when the new Construction Phase cement layer partially disappears. Any thoughts ?
Replies (11)
Message 2 of 12
What's the View Phase Filter set to?
Is the issue replicable? Create another like View and see.
Message 3 of 12
stephen.melhuish
Strange, I take a different 3D view, this time of the rear and get a different result for 2 different locations of the same elevation (see attached)
Message 4 of 12
Message 5 of 12
Are you using sketchy lines?
Try disabling Hardware Acceleration.
Help: Hardware Acceleration (autodesk.com)
Message 6 of 12
stephen.melhuish
Unfortunately still no luck I'm afraid. I disabled hardware acceleration and re-started revit but still got the same problem. I'll re-do the perspective views and see if that will resolve matters
Message 7 of 12
How thin is the plaster wall?
Message 8 of 12
stephen.melhuish
The cement render is just 20mm thick. However, the same is also occuring with timber cladding which is 20mm thick with 25mm air behind
Message 9 of 12
BIM-CONG
It seems like that the two "walls" including brick and cement ara overlapped.
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
- BIM THE FUTURE -
Message 10 of 12
stephen.melhuish
They don't overlap but I have found that if I move the New Construction wall I placed over the Existing wall away from the Existing wall then it seems to work.
Message 11 of 12
syman2000
Do you have any CAD link or heavy 3d family inside the project?
Message 12 of 12
BIM-CONG
Emmm it's a little strange, can you post a partial model with this issue?
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
- BIM THE FUTURE -
