Vertical batts in wall assembly.
6 ANTWORTEN 6
Nachricht 1 von 7
stulsankar
360 Aufrufe, 6 Antworten
it will be great to have a modify option in wall assembly to add vertical batts or boards on wall, in similar manner like we have the option to add horizontal sweeps.
Tags (1)
Beschriftungen (2)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: stulsankar
No can do, but do you really want to do that?  Have all that squiggly linework show in every Section View/at every View Scale?
...we are talking about batt insulation; right?
Nachricht 3 von 7
Nachricht 4 von 7
What about a Batt Hatch Pattern instead?
Nachricht 5 von 7
stulsankar
als Antwort auf: barthbradley
Want it be seen in 3d and rendering
Nachricht 6 von 7
Rendering??? So, we aren't talking about squiggly linework.  Why don't you create a material that is Dow Pink? Know what I mean?
Nachricht 7 von 7
If you really want to knock yourself out, you could create the stud/batt insulation Wall Layer with a Curtain Wall. Studs=Mullions. Batt Insulation=Panels.  Then use Basic Wall Types for finish layers.
