Recessed door
austin.garst
Recessed door
austin.garst
Hello all,
I am learning Revit MEP for my company. But I don't have the CAD or Revit models from the architects, so I am having to sketch the building from the 2D plans they sent over. I'm having to sketch the architectural elements. I'm having a difficult time creating the recessed outer door way. What I did was draw the walls, and create a small room, split the outer wall out. And it will serve for my purposes, but I am wondering what the correct way to do this is. Right now, the recessed doorway is open on the top. How do I enclose it? And what was the correct way to achieve this.
Thanks.
Replies (21)
Looks right to me.  Build the recess with walls, roof/floor (to cap it off).  Basically, the way that you want it built in the field.
Build a ceiling above the door way.
If you are wondering how to get the CMU to look like it's wrapping the corner, change your Wall Join.
austin.garst
I don't know how to give that small wall section it's own ceiling like you did.
austin.garst
The walls are the right height. This space is a shell space and will have exposed ceiling. So I just need to put in the 2nd level floor, and that should be sufficient for the ceiling right? Do I just need to create a ceiling for the door space? I will enclose an image of what is specified for the ceiling material of that recessed doorway. recessed door ceiling.PNG
You could add Level 2 if there is actually a floor or roof above, but you don't need it for the ceiling. Open, or create a new, reflected ceiling plan view of Level 1 and draw the ceiling with an offset value from Level 1.
Create a Flat Compound Layered Floor or Roof on Level 1, go to a Section/Elevation and move the Floor/Roof up. Easy breezy.
austin.garst
I need the recessed doorway to have the ceiling, not the entire level. I am aware of how to give my model a ceiling for the entire level. I'm confused about the recessed doorway.
Strickly speaking, that's not a "ceiling" you are showing in your cross-section.
Never told you to draw the ceiling over the entire level.  Draw the ceiling boundary the same size of your recess area.
https://knowledge.autodesk.com/community/screencast/dd90e7ac-edf2-4afc-a771-5ece4f39f66f
austin.garst
I know, it's almost like a horizontal wall. Do you know how I do that?
You mean the build up?  It's a Compound Layered Assembly. You can do the same with Roofs, Floors ...and Ceilings.  The reason I say to use a Roof or Floor is because that "cap", so to speak, will be Framed in.  Ceilings are generally Finish work.
austin.garst
Dude thank you so much.
If proper naming is one of your things, then rename that ceiling type to Exterior Soffit because that is what it is.
You're welcome.
Now go ahead and mark my post as one of the accepted solutions as well.
austin.garst
I appreciate the little video! Proper naming is not really my thing. I just don't often know what exactly to look up or how to describe certain things. My working experience is on the mechanical side. Trying to do the architectural stuff is pretty new to me.
I notice you are throwing solution credits out right and left but forgot me.  Any reason for that?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
