Parts Height
Parts Height
alan_eu
Advisor Advisor
Message 1 of 19
Parts Height
alan_eu
Someone knows an easy way to change multiple parts height?
Maybe even using a plugin or dynamo...
Actually, we can do this one by one, pushing its shape handles...
Thanks!
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
Accepted solutions (3)
Replies (18)
Message 2 of 19
What is the original of those parts? Why wouldn't you create the original with the intended dimensions before converting it to parts?
Message 3 of 19
alan_eu
Cause I could save many work hours doing so.
I need to select wall parts with white paint, for example, and just decrease its height once by 1m. Unfortunatly, I can´t change the parts height, except for pushing its shape handles one by one...
Doing this, instead, directly on the wall, I will need to do many sections views, Split elements, to change types, etc
Message 4 of 19
Unlock the white paint layer of the wall type, select the walls, and change top extension distance to -1m.
Message 5 of 19
alan_eu
Thanks for your reply!
That´s a way more complex than this what want to achieve...
Actually, I´m looking for a better solution using parts to optimize this process 🙂
Message 6 of 19
How is a 3-step workflow which does not involve a custom dynamo script complex?
Message 7 of 19
martijn_pater
Just wondering if you should be using parts at all...
Message 8 of 19
alan_eu
Imagine the situation where you have to decrease the internal wall layers below the ceiling, but some of these layers should be 50cm above that same ceiling.
At the same time, the inner layers of the WC walls must use a different height and also different colors/materials and on the other side of the same wall, I have a bedroom or even an external facade face with different materials or height.
Normally, I do exactly what you are saying. But it takes maybe 1 or 2 workdays to do that for maybe 1000 walls... one by one, using normal walls (adjusting its heights and wall types and many horizontal SL - split element) OR I could do this with 15 minutes, using parts, and just selecting the specific parts on its schedule and modifying its heights... The problem is: Revit alone doesn´t allow me to do this with multiple parts...
So I´m looking for a plugin or dynamo speed up the journey 🙂
Message 9 of 19
The workflow I told you does not involve splitting elements.  Where did it come from?
Message 10 of 19
alan_eu
Hi @ToanDN
I appreciate your help, really. But the workflow you told me is a  supposition that doesn´t resolve my optimization desire, except for very simple and specific situations, but not so useful overall in my case...
I know I could make many different walls for each occasion; I know I could configure its heights on the Wall edit type/modify section tab, and even know how to control the wall heights on the wall schedules.
The real problem here is how to optimize 1000 walls made like this (it´s just a random example):
6Chvnw3
Message 11 of 19
Sorry pal but I don't think you understand the workflow. It does not involve any of the complexity you said above.  You asked how to reduce the height of a wall layer of multiple walls by 0ne meter and that is exactly how you do it.
Message 12 of 19
martijn_pater
@alan_eu I think perhaps you might have to be more specific what your walls and parts look like, ie.how you did the division sketch. Possibly share an .rvt file showcasing the issue. In general those 3 steps @ToanDN showed you would work I think, it's a bit unclear for your situation though. So if it's not a solution, be more specific. 🙂
Message 13 of 19
alan_eu
Hey @martijn_pater and @ToanDN !
The real issue here isn´t about how to use Revit, but how to optimize this process... Probably using plugins or Dynamo...
Actually, there is too manual and repetitive process involved...
With a closer look at my last image, you should notice the wall finishes on both sides are different, and also, each side has some different materials, each one with different heights. So, I can´t just use "Top Extension Distance".
hBPP2go
Message 14 of 19
martijn_pater
Something peculiar about that... but anyway, I guess then you could use Align Multiple (ribbon checkbox) to a level/reference plane ie, if you would do this from the start you could just move that up or down... Although in general I guess it's better to not lock too much, but here it might be useful. I don't know how you would do it using Dynamo, but I suppose it's possible... or you could start aligning 1000 walls, should be doable before chrismas... ^^
Message 15 of 19
Are there any rules to these dimensions accrossing all walls or are they different from one wall to the next?
Message 16 of 19
alan_eu
@martijn_paterThanks for the encouragement 😂 😂 😂
@ToanDN There are some rules defined by room. Most bathrooms, bedrooms, etc, has their own set of material and height configurations. Except for some exceptions 🙂
Message 17 of 19
Create a parametric profile family with different types for different rules and use it to create different wall reveal types to trim off the wall layers.
Message 18 of 19
alan_eu
Sounds interesting. Would work with reveals or even a void on face based family.
I have to test it using ifc file export to see their use outside Autodesk also.
Thank you for the ideas @ToanDN @martijn_pater 👊😎
ps. I´m still looking for a good parts management plugin or dynamo. It would work even better 😉
Message 19 of 19
rani
Hi, Alan... Are you still looking for the solution?  Me too.. rssrs.  Why don't you/we put this in Revit ideas? And ask for people to vote? It would be a dream to have a native solution, and I think it would be the best workflow, without plugin ou Dynamo rotines.
