Parametric Rectangular Family
14 REPLIES 14
Message 1 of 15
shahin_kiyomarsi
579 Views, 14 Replies
How can I create a rectangular family thats parametric. I want to have arrows where I can make it bigger/smaller instead of number parameters
14 REPLIES 14
Message 2 of 15
in reply to: shahin_kiyomarsi
Add reference lines and constrain them with instance parameters then you can have stretch grips in the project.
Message 3 of 15
shahin_kiyomarsi
in reply to: ToanDN
I want these arrows to show up when I upload this family into my project. So I can drag the arrows to change the size
Message 4 of 15
Are you trying to get the arrow grip to show up in 3d?
To get the arrow to show in 3d, you have to setup your rig (see screenshot)
Once you have the rig setup, you should see your grip in 3d view.
Message 5 of 15
No I want to do it in plan view.
Something like this
Message 6 of 15
As I already said, you need to place ref planes or ref lines on all (4) sides and run your instance parameter dimensions to those planes.  Then constrain your model geometry or linework to those planes.  Place dimensions directly to your model geometry or linework does not work.
Message 7 of 15
@ToanDN already gave you the answers in the first reply. If you really want to show the triangle grip quickly, then select the dimension and click on instance parameter.
Message 8 of 15
shahin_kiyomarsi
in reply to: ToanDN
Sorry kinda lost.
I put the Width / Length dimensions to the reference planes
The EQ dimensions should be to the model?
Any other dimensions i need to put?
Message 9 of 15
Sorry kinda lost.
No.  All dimensions are to ref planes.
No.
N
Message 10 of 15
shahin_kiyomarsi
in reply to: ToanDN
I did that, now the whole box shifts.
All the dimensions are to the reference planes.
Message 11 of 15
Have you made Width and Length instance parameters yet?
Message 12 of 15
shahin_kiyomarsi
in reply to: ToanDN
Yes, I attached the file.
Message 13 of 15
Do you want each of those grip operating independently?
Then remove the middle reference plane and set it to reference rectangle box to origin reference plane.
If you set EQ to the length, this means stretching the length or width will stretch both consistently.
Message 14 of 15
Lock the line to the reference plane
Message 15 of 15
- The Width and Length parameters should NOT be locked.
- Edit the extrusion and constrain their boundary lines to the ref planes.
See revised file.
Forma Design Contest
