parametric mean
parametric mean
Message 1 of 8
parametric mean
What does parametric mean, and how does the parametric change engine keep
everything updated when I make changes? Why is the concept important?
Replies (7)
Message 2 of 8
lucdoucet_msdl
@Anonymous
Parametric will have different meanings depending on the context. I will assume for the moment that you are refering to the mechanics of the software package and not in terms of architecture or design.
That would be a better question for the Revit API Forum. But here's a link to the wikipedia article on the origin of the name Revit: Wikipedia.
Ah, a better question question for this forum. From the history section of the Wikipedia article you will note that:
"At the heart of Revit is a parametric change propagation engine that relied on a new technology, context-driven parametrics, that was more scalable than the variational and history-driven parametrics used in mechanical CAD software.[4] The term Parametric Building Model was adopted to reflect the fact that changes to parameters drove the whole building model and associated documentation, not just individual components."
As related to the task of modelling a building, non-parametric software will create a static model requiring the user to effect all changes intentionally. With software that includes parametric components, the updating of these components by changing the values of the parameters is a combination of time savings and respecting the design intent that is incorporated in the algorithms the user has embedded in the parametric components. When the entire (or close to - some things can't be parametrically driven)  model is parametrically enabled, which is the case of Revit, the efficiencies and parametric design possibilities are scaled up considerally.
At this point, it would  useful to include  the concept of parametric design in the discussion as well as come back to "how does the parametric change engine ...". I would propose that there are three types of parametric interactions: a "fixed - hard coded" set of parametric operations, an "open" system of families and a "computational" functionality thru the API and the use of Dynamo.
But that is a more philosophical question.
-luc
Message 3 of 8
_Vijay
there plenty of video's on you tube and other platforms explain what is parametric family. But here some reference for you.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 4 of 8
RobDraw
Homework question?
Rob
Message 5 of 8
yes... hahaha
Message 6 of 8
RobDraw
@Anonymous wrote:
yes... hahaha
Not funny asking us to do your homework. Earn your education yourself.
Rob
Message 7 of 8
I already did but that was for confirming my answer ...
thanks for advice
Message 8 of 8
The term parametric in this context refers to the relationships among and between all
elements of the model that enable the coordination and change management that Revit
Architecture provides. These relationships are created either automatically by the software
or deliberately by the user as they work.
A fundamental characteristic of a building information modeling application is the ability to
coordinate changes and maintain consistency at all times. The user does not have to
intervene to update drawings, links, tags, and so forth.
This concept is important because it is this capability that delivers the fundamental
coordination and productivity benefits of Revit Architecture: Change anything at any time
anywhere in the project and Revit Architecture coordinates that change through the entire
project. This change management is also one of the fundamental characteristics of a BIM
solution.
If my post answers your question,  please click the "Accept as Solution" button.  This helps everyone find answers more quickly!
