Announcements
How do I make a tapered roof assembly with a flat bottom?
I'm trying to model a "flat" roof with (from bottom to top) level 2x12's, tapered 2x4's, OSB, rigid insulation, EPDM. I've created the assembly and I check off the "Variable" checkbox next to the 2x4 layer, but it does nothing. The assembly slopes on the top and bottom, with or without the "Variable" box checked. What am I doing wrong?
I've attached a screenshot below. TIA!
Replies (13)
Variable thickness takes effect when you model a flat roof and use modify subelements to alter the slopes.
zeulrick
Try duplicating the roof and eliminating the finishes on top of the structure. Copy this roof (with only structure) below the roof with 0 slope and join it to the roof assembly above. Its a hack, not a great solution but would be better than a masking region option...
Out of curiosity, what would you expect checking "Variable" to do?
Not this; right?
martijn_pater
@Anonymous You can check variable in roof type assembly for the tapered layer and use modify subelements.
Alternatively you could model the roof geometry in-place.
Thanks for your response, ToanDN. That is what I am attempting to do, though I assume I'm missing a step (or more).
Thanks for your response, zeulrick. This worked, sort of. Good to know as hack, though I'd like to figure out how to do this correctly.
Thanks for your response, barthbradley. That is what I would expect it to do. Clearly, I'm doing something wrong. Any suggestions?
Well, first off, you need full Revit with "Modify Sub Elements" tools. LT doesn't. Second, you Edit Structure of a Floor or Roof System Family Type and in it's Edit Assembly dialog box, check the  "Variable" checkbox next to the layer that will be variable thickness.  Third, sketch a FLAT Roof or Floor with that "Variable" Family Type -- No Slope Arrows; No Defined Slopes.  Finish to exit out of sketch mode, select the Floor/Roof, and press "Modify Sub Elements" to activate shape editing mode/tools.  In that mode you can change point and edge elevations, and/or add addition points and edges to the flat, "Variable" Floor/Roof  .
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Model/files/GUID-D7240EA9-28EB-4F51-A474-371FA0DFBFAF-htm.html#:~:text=Modify%20the%20Shape%20of%20a%20Roof%20or%20Structural,height%20represents%20the%20offset%20from%20the%20...%20
The key is you must create a FLAT roof from the get go, then use modify subelements to add points and/or lines and change their elevation to add slopes.  The result is a roof with a flat bottom and sloped top.
Thank you! I do have full Revit, so I do have the "Modify Sub Elements". My error was in still trying to use the Slope Arrows. I had thought that I could use them to define a specific slope (1/4":1'), so that if I change change the footprint in the future it would be constrained by the Slope and adjust the assembly thickness accordingly. Seems like it would be nice to have this functionality, so a roofer doesn't end up wondering where they're supposed to get 7/32":1' tapered insulation, but it's definitely not a big deal.
mikebZP76Q
These solutions work if your roof has a perfectly square or rectangular boundary. A condition that is virtually non-existent in most real world projects. If you have any cut-outs, jogs, etc, the roof will then the addition of say, a split line at a higher elevation, will create non-orthogonal pitches that have no practical drainage purposes.
You can try starting as a square or rectangle, and then trimming out the cut-outs- but it leads to the same result. Autodesk has only had 24 years to figure this out. I'll try to be more patient. Until then, thankfully Rhino exists.
EWE-G5
This is absolutely frustrating. Instead of one roof, I need to make two, one sloped and another flat, then pray they join without any error. If I make a change of an opening within roof boundary, I need to edit both of them, even if in real it should really be just one roof... To add even more to that, you never know if your revit roof is one more opening from crashing, or saying it has to unjoin/uncut everything what you've done before.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
