Using nested Revit links with Docs
claireRHQV7
claireRHQV7
I have received a Revit model from an architect with several nested links. There are bathroom links nested into individual unit links, which are nested into an overall unit model, which is nested into a whole building model. I generally download one overall model, put it into Docs, and then link the architect's model into my interior model, but I am having difficulty getting all the links to load by using Docs. The links appear to work on my desktop but I will not have worksharing capabilities. Do multiple nested links work with Docs?
David_W_Koch
@claireRHQV7
Welecome to the community!
They do, but would work best if all of the linked models were also uploaded to Docs as Revit Cloud Workshared models.  Then you would need to reload the links from the new cloud versions.
If these are attached links, the reloading should be done in the main architectural model that you are linking.  If they are overlays, then you will need to load then into your model directly to see them.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
handjonathan
Hi @claireRHQV7
Thanks a lot for posting your question to the forums!   Has the solution suggested by @David_W_Koch  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
