Revit - Edges to sloped curved slabs
vitorbortoncello
Advisor Advisor
vitorbortoncello
How can i add a slab edge to a curved sloped floor?
I already tried this, but it didn't work: work: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Adding-edges-to-sl...
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Use 3D Snapping Beams.
...how 'bout Walls that are attached to Top/Base?
Attach to Base reference floor hidden in above View screenshot.
Add the slab edge when the slab is flat then change the slope should work.
Aside from what has been suggested, you can also model it as a swept blend.  A railing would work visually but not structurally (rebars and such).
vitorbortoncello
3D Snapping Beams did not work;
Walls worked fine but my profile is not a retangular one;
I tried using a swept blend and it worked too.
