Message 1 of 11
- Mute
- Permalink
- Report
Hello - please help!
I’m trying to create a parametric cabinet which has the following constraints:
- Height, width and depth all parametric.
- Cabinet doors to be a max of 450mm
- If width of cabinet exceeds a multiple of 450mm then doors must divide equally by the width.
E.g. if the cabinet width is 1200mm then each door would be 400mm wide.
So far, I can flex height, width and depth. Cabinet doors also flex, but exceed desired max 450mm width.
Any advice would be fantastic. I’m more than happy to share with the community if I can figure it out.
Thank you.
