Precast stair that begin and end with tread. How to hide first and last step of a stair in plan?
8 ANTWORTEN 8
Nachricht 1 von 9
solbess
1730 Aufrufe, 8 Antworten
I have made a precast stair. Begin and end with riser is unticked, so that the first and last tread is level with the landings, and the stairs are connected with a notch.
The problem is that even if these treads are level with the landings, they appear in plan view and makes the landings look very narrow. I have managed to make the direction arrow begin and end with the first and last risers.
Is there a way to make the first and last step dissappear in plan?
These treads are merely there for practical reasons, and should not be visible in plan.
Beschriftungen (4)
8 ANTWORTEN 8
Nachricht 2 von 9
alan.johnson7YLND
als Antwort auf: solbess
In the plan view you could use a Masking Region (set the boundary to invisible lines), or you could use the Linework tool
(on the modify tab) to override the line style to invisible lines.
Nachricht 3 von 9
alan.johnson7YLND
In plan view
Use the masking region tool (on the Annotate tab) set the boundary line to invisible
start to draw a rectangle to cover the lines for the last riser
drag the mask along until you have covered all the lines you want to hide
once you have the mask in place it will hide the lines underneath.
Nachricht 4 von 9
solbess
als Antwort auf: alan.johnson7YLND
Thanks for your reply.
This is a possible way, and will make the graphics look right.
Howeverer, it would be good if this was happening automatically, at least possible to hide at certain scales, as this is not a line that would normally be visible in a plan drawing
Nachricht 5 von 9
alan.johnson7YLND
The issue you have is, in your plan view Revit is showing the stair as you have modelled it.
So you either have to mask the bits you don't want to see or you would need to model the stairs differently.
Nachricht 6 von 9
RDAOU
@solbess
By unchecking the start/begin with riser, you have set it to level the last and first tread with the landing!!.
  • Either edit the landing so that they do not overlap and look right
  • Or re-apply the start with riser and change the desired number of risers to maintain the desired number of tread...ie: the landing will act as the last Tread (no need to join and no need to hide)
Nachricht 7 von 9
solbess
als Antwort auf: RDAOU
I am not sure if your proposed solution is possible while maintaining the notch connection of the precast stair?
Nachricht 8 von 9
RDAOU
@solbess
I probably misunderstood something ... See Gif Below
Nachricht 9 von 9
Use Linework tool to assign <Invisible Lines>.
