Parametric bench
Parametric bench
dn_setshogoe
Parametric bench
dn_setshogoe
Hello everyone,
Does anyone know how to create benches like tthe ones below STRICTLY USING PARAMETRIC FORMULA?
1-Parametric-design-the-Curvilign-Bench-a-furniture-concept-by-Clément-Loyer.jpg4-Top-view-of-this-bench-concept-by-Clément-Loyer-an-architecture-student-from-La-Baule-Escoublac-France.jpgParametric-Bench-Interior-Design-by-Oleg-Soroko-23325235.jpg
Kind regards,
Dirang
Keith_Wilkinson
How exactly would you want this to be parametric? Looks like a one off bespoke item in which parametrics would be of little use...
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
nathan.chapman
Within a family that would be very complicated and one heavy family in a project.  Your best bet would be using massing and Dynamo. http://dynamobim.org/.  Dynamo is a very good tool for complex shapes and changes on the fly.  Now there is a little learning curve to get over but once your past that its a great tool.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
chrisplyler
I have absolutely no idea. But I do know that forms can be created out of the profile lines of other forms.
RDAOU
@dn_setshogoe
what @chrisplyler briefly described is the right way to approach such design. It make it parametrical, you will need to put some trigonometry and algebra into it. If you need to randomize it
  1. Manually ... Those points should be easily controllable by their Normalized Curve Parameter (either manually or by dependent formulas)
  2. OR Use couple of adaptive points to act as attractors which control the the NCP of those points depending on where you host them (if you are confident you can model/handle adaptive families)
  3. OR Use Dynamo as somewhat suggested above and what the script does basically is randomize the NCP of those points based on a certain given input (although you do not really need to - what you have is organic in shape but pretty much basic so you do not need to complicate it.) a similar concept we use for automatic kinetic curtain panels where the given input in such case is the location of the Sun which the script fetch from Revit (a little bit of Python scripting might be needed unless someone compiled a node in Dynamo that does it all - I haven't come across any thou)
cheers
