I'm using Revit 2016.
All the updates are installed.
When I try to export to IFC there is no settings window, instead a file browser opens to enter saved file location and name.
As far as I know there was supposed to be an IFC settigns window when choosing export -> IFC.
To illustrate what is happening, here is a quick screen video (also attached as attachment)
https://dl.dropboxusercontent.com/s/tp2blwpqlwx272n/2016-09-01_13-30-11.mp4?dl=0
how can I get my IFC export settigns back? Any ideas?
Gelöst! Gehe zur Lösung
Gelöst von Keith_Wilkinson. Gehe zur Lösung
Do you have the open source IFC exporter installed? It has a lot of additional functionality over the OOTB version.
https://sourceforge.net/projects/ifcexporter/
Thank you. That was the solution.
I forgot, that you had to install additional stuff, to get those options.
