- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I have some trouble transferring parameters in nested families. The issue I have is most clearly described as follows:
- I create a generic model family (Let's call it GM1) with for example a length dimension which I make a parameter. As a result the parameter shows in the Family Types menu, in which I can change it's value and the correspondent length changes with it. The model is workplane based.
- I create a new generic model family (GM2) in which I create a reference line with an angle (XY angle). This angle is also added as a parameter. Next I nest GM1 on the reference line. This nested GM1 now has at the Family types menu the parameter angle, which I can change with no problem. And in the properties of the GM1 model it has the dimension length which I can change with no problem. Again I make the family workplane based.
But now comes the problem
- I create a new generic model (GM3) in which I create a reference line with an angle (Z angle). In this family I nest GM2 on the reference line. At the Family Types menu I have the Z angle which I can alter with no problem (GM2 alters with it), but in the properties menu of the model, I now only have the XY angle dimension. So in the process of nesting GM2 in GM3 the Length dimension parameter of GM1 has disappeared.
I'm hoping someone can tell me why the parameters are only transferring to the first family it is nested in. All parameters are instance parameters classified as length or angle.
Peter
