Parameter to report overall area of building
10 REPLIES 10
Message 1 of 11
Sahay_R
733 Views, 10 Replies
Is it possible to create a parameter to populate this on a project Cover Sheet?
This is a family, that is inserted into the Cover Sheet.
Thank you!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
10 REPLIES 10
Message 2 of 11
in reply to: Sahay_R
A shared parameter under Project Information. Populate it using keyboard ;). Or dynamo.
Message 3 of 11
Sahay_R
in reply to: ToanDN
Please clarify the evil grin?
Also - how in Dynamo?
Rina Sahay
Message 4 of 11
sgoodmansen
This could be easily done with an Area Plan and corresponding Schedule.  That way it stays up to date if the Area changes.
Message 5 of 11
I assumed you wanted the parameter to pick up the value based on the actual model, hence the smile after " populate using keyboard". Dynamo? It can calculate something and write to something else, can't it?
Message 6 of 11
loboarch
in reply to: sgoodmansen
Here is what it might look like using a schedule. This of course depends on you creating an area plan for the project. It could be done with a room schedule I suppose as well. The formatting is a bit challenging if it need to look EXACTLY like you showed. This method has the advantage that it will automatically update as long as area/room plan is kept up to date.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 7 of 11
Sahay_R
in reply to: loboarch
@loboarch - so the area is a label with a shared parameter that talks to the area plan?
Rina Sahay
Message 8 of 11
You place the schedule directly on the cover sheet in project.
Message 9 of 11
sgoodmansen
The schedule value is a calculated value, so is not a parameter.  You can make a shared parameter for total area, but will always need to update the parameter manually when the area changes.
Message 10 of 11
loboarch
Nope. I did this with just an area plan. Just added the "Area" parameter to the schedule and told it to calculate totals on the formatting tab. I also cleared "Itemize Every Instance" on sorting and grouping tab so I don't get each area listed, just the total. Messed a bit with the formatting and headers of the schedule (this is where you are kind of limited.) placed it on a sheet. You can even place it on multiple sheets if you wish.
Jeff Hanson
Revit Help |
Message 11 of 11
Sahay_R
Marveloso! @loboarch you are my hero!! Thank you everyone!
Rina Sahay
Forma Design Contest
Technology Administrators
