Hi all,
I have an issue while working out the pricing of benches (panels).
Please see the images below. This is a simple multiplication that for some reason Revit is not doing right (or maybe I do not know what is the reason why is getting this issue.
The total price here should be 1 for some reason is giving 10.76. Has anyone had this issue before? many thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von GustavoUbriaco. Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Can you upload the model to check it?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Your parameter "price per m^2" has as unit "price per square foot"
1 m2 = 10.76 foot2
If I override the unit in the schedule to price per square meter
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks for that @L.Maas & @GustavoUbriaco! That made sense. Really appreciate your help ![]()
