Create a view perpendicular to Ref- plane
3 ANTWORTEN 3
Nachricht 1 von 4
info
300 Aufrufe, 3 Antworten
I want to create a sloped wall - I have revit 2020. so I have to create a wall in-place.
How can I create on view a ref- plane face on if it's not aligned with main directions?
(Please see attached)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: info
Place a section and you can draw the section line on the ref plane.
Nachricht 3 von 4
info
als Antwort auf: ToanDN
HI ToanDN,
Thank-you once again for your port.
Yes. After I posted I realised I could use a section cut and align it with Ref - Plane.
I'm use to using Solidworks were orientating your work plane is a-lot easier.
Nachricht 4 von 4
Out of curiosity, why do you need that Ref. Plane?
