Overall price from square meter rates
5 REPLIES 5
Jonas-Glez-Mar-Tej
354 Views, 5 Replies
Hi all,
I have an issue while working out the pricing of benches (panels).
Please see the images below. This is a simple multiplication that for some reason Revit is not doing right (or maybe I do not know what is the reason why is getting this issue.
The total price here should be 1 for some reason is giving 10.76. Has anyone had this issue before? many thanks in advance.
Labels (1)
5 REPLIES 5
rxi.gg
in reply to: Jonas-Glez-Mar-Tej
Can you upload the model to check it?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Jonas-Glez-Mar-Tej
in reply to: rxi.gg
See below
L.Maas
Your parameter "price per m^2" has as unit "price per square foot"
1 m2 = 10.76 foot2
If I override the unit in the schedule to price per square meter
Louis
Please mention Revit version, especially when uploading Revit files.
Justo lo  que dice @L.Maas fue un pequeño error en las unidades en ese parámetro
Gustavo Ubriaco Contreras
Thanks for that @L.Maas & @GustavoUbriaco! That made sense. Really appreciate your help 😉
