Opening/Shaft with variable widths
Raymarcher
Raymarcher
How can this be achieved in Revit?
It seems the opening/Shaft tools are rather limited?
Greetings
2018-08-10 01_45_17-wee.max - Autodesk 3ds Max 2020 pre-release - Not for Resale (Athena with PDBs A.png2018-08-10 01_44_47-wee.max - Autodesk 3ds Max 2020 pre-release - Not for Resale (Athena with PDBs A.png
Accepted solutions (3)
Sweep Blend
Corsten.Au
Create inplace model..instead of shaft.Create inplace model..instead of shaft.
Corsten
Building Designer
Or use a two-level generic family with a parametric void sweep blend to control the sizes of the top and bottom profile. Load in project and set the base at the lowest level, the top at the highest level, and use cut geometry to cut all the floors in between.
