Open IFC file error
Open IFC file error
Open IFC file error
I'm trying to open a IFC file in Revit, but once done, I receive an error message saying : "The following problems were encountered in the IFC file : No building elements were found in the file.".
Has anyone ever encounter this issue?
I also try to import the IFC in a new project and it didn't work either... I tried to change the "Phase filter" to "Show all" and the "Phase" to "Latest", nothing appeared.
I also want you to know that I didn't create the IFC file, I received it from a client.
Any ideas?
William
peter.dragovic
Having same issue when importing rebar from allplan into Revit....and Navisworks...Autodesk we need this issue to be solved.
Seeking for a solution for the same concern
Some one please give solution for the error, I'm also facing the same
Any ideas?
William
peter.dragovic
My solution was to import 3D solid dwg. It sucks but i had deadline.
nmarcelis
I had the same issues in the past.
Try change the IFC options before linking it into the project.
You can find more information about this here
Let me know this helped you.
Revit Certified Professional Architecture, Structure and MEP.
marekga
Hello. Try to convert that IFC file into RVT file using older version of revit. It helped in my case at least. Originally problem occured when trying to open in Revit 2023, but when trying convertion in Revit 2022, that message didn't show up, and file has been converted.
