Nachricht 1 von 6
mrheuseler
296 Aufrufe, 5 Antworten
Wall
I'm having a problem with a wall.
By filter (Or something like that) i need "number 1" wall to look like "number 2" wall.
Is that even possible?
(Need the main lines in the wall, and one line in the wall, needs to be "hidden".
Please see attached picture.
Thanks for your help.
Kind regards Morten
5 ANTWORTEN 5
Nachricht 2 von 6
ramsuhas7
als Antwort auf: mrheuseler
Select the wall which you want to change and in properties panel click edit type and type properties window popups. From the families (top left corner) select the wall which you want it change.
Nachricht 3 von 6
Sounds to me like you want to change Wall Cut Line Styles in View.
Nachricht 4 von 6
Ilic.Andrej
If you need this for some particular walls, see this solution. Its a bit dirty though....
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 5 von 6
mrheuseler
als Antwort auf: Ilic.Andrej
Wow - thank you. This might come in handy!
Nachricht 6 von 6
Ilic.Andrej
You re welcome :leicht_lächelndes_Gesicht:
Andrej Ilić
MSc Arch
