Open 2021 revit file from 2020 file
Hello! I'm facing a situation, I was wondering if there's any other solution to open Revit files from an older version than using IFC's until now I've been exporting from 2021 to IFC and then I open it on 2020 but I cannot see the topography, annotations, and others, only architecture. Is there another solution to view the elements inside the 2021 file?
Thank you!
Samantha-G
Hi @Anonymous
Thank you for the question.  There really is not a good workflow for what you are trying to do.  You can work the way you have been but there will be data lost.  It is recommended that all people on a project be on the same version, due to Revit not being backwards compatible.
Sam G, CM-BIM
Revit Certified Professional
Thank you for your answer. Have a nice day.
tfergusonPZ6ND
Observer
Observer
Why would you not allow backwards combability Samantha?  This seems to be a decision by Autodesk to better control their products "financial strength" at the cost of its customers.
stian.engelstad
Its been explained it pretty good detail by Sasha.Crotty in this thread.
