Offset From Host issues
Message 1 of 9
Hi!  I’m wondering if anyone can help me figure how to offset a mattress. I’m currently building some cubbies for a hostel and for some reason Revit will not let me offset my mattress to put in my cubbies.
Replies (8)
Message 2 of 9
Post the Family.
Message 3 of 9
It’s just the regular twin standard bed 38”x75. I removed the box spring and legs because I just needed the mattress.
Message 4 of 9
Message 5 of 9
Try checking "Work Plane-Based" and unchecking "Always Vertical" in Family.  When you place instance in Project, pay attention to the placement options on the Contextual Tab.
Message 6 of 9
Unfortunately that still didn’t work. It didn’t give me an option to offset it from host.
Message 7 of 9
Host it to a NAMED Reference Plane and move the Reference Plane in Elevation.
...or build an OFFSET/Parameter in the Family itself
Message 8 of 9
Thank you! That didn’t work either so I just used mass to make a box and I went from there. Thank you though!
Message 9 of 9
Mass??? Wow!  You are on a different planet now. Ha!
It works the way I described. You just didn't follow my instructions.  Want me to repeat them, or are you happy with your interstellar workaround?
