Not able to see walls in the plan view
5 REPLIES 5
ahirani24
378 Views, 5 Replies
For some reason, I am not able to see the windows of my building in plan view.
I have attached the screenshot.
5 REPLIES 5
RDAOU
in reply to: ahirani24
@ahirani24
First guess; Check the cut plane level in the view range (properties palette) ... it should be above the window sill
ahirani24
in reply to: RDAOU
@RDAOU How do I do that?
ahirani24
in reply to: RDAOU
@RDAOU  This solved it. But can you direct me to a video that explains the view range property function properly.
I want to understand:
1) What does offset from Top: mean
2) What does Primary Range mean?
3) What does view depth mean
4) What does offset from bottom mean?
RDAOU
@ahirani24
Check this post here...Solved: View Range in Revit - Autodesk Community - Revit Products
It has a long explanation if you are ok with reading and a screencast video
