Good day, I'm trying to create a radius using a foundation wall, the two walls are different thicknesses. One wall thickness is 6" and the connecting wall is 2'-0" thick. See attached drawings.
This may not be possible using the Structural Wall > Foundation Wall, instead use the Architectural Wall > Foundation Wall where the wall design can be sketched.
Create an in place void to cut the corner of the wider foundation wall to create the radius.
https://knowledge.autodesk.com/community/screencast/2e73690c-e6bd-4423-84ca-1760e6e00905
