Message 1 of 18
Non-Room Bounding Wall still bounds room
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have a project on BIM 360 Teams were several soffit walls aren't acting as they should.
They have a base offset from the floor 7'-6" and go up to the level above.
The room bounding check box is unchecked.
However the wall is still room bounding.
If you check the room bounding check box, apply the properties and then uncheck the box again, the wall behaves as intended and the room appears fine. However as soon as you save the wall seems to be acting as if it's room bounding and room no longer fills that space.
I've also check Ceilings and those are also not set to room bounding.
it doesn't appear to be happening on every soffit wall, but those are the only walls that it seems to be impacting.
Has anyone else run across this issue?
Thanks!
