No storefront wall type
7 REPLIES 7
Message 1 of 8
steve
3859 Views, 7 Replies
I have started a project a while back - lets call it "workproject"   - I believe it was an "architecture" type template.  When I try to create a storefront type curtain wall, there is none listed in the project browser.   https://goo.gl/wTSzFA. Perhaps "unused families" purge was done.
if i start from scratch with either architecture or commercial type standard templates there are 3 curtain wall types, lets call this "testproject"  as I would expect.   https://goo.gl/1TQ8Gi      When I use manage / transfer project standards from testproject to workproject  to bring in the wall types not found in the work project, they still are not found in the workproject.
Import Project Standards allows other wall types to be imported, but NOT curtainwall types.  How can I bring in Curtainwall types from other projects ?
7 REPLIES 7
Message 2 of 8
in reply to: steve
Message 3 of 8
steve
in reply to: ToanDN
duh.  Brilliant, of course!  Hiding in plain site.  Thanks ToanDN   that works.
Message 4 of 8
steve
in reply to: ToanDN
where is this "copy from" command found?  r2019
Message 5 of 8
ennujozlagam
in reply to: steve
any  revit version have (open a new file and your current file) then  go to manage and use transfer project standards to select those you need. thanks
Message 6 of 8
juan9FK2B
in reply to: steve
A picture gave you the answer?
Message 7 of 8
in reply to: juan9FK2B
Apparently.  To clarify, create a new project from the architectural template and Transfer Project Standards.  Then it will bring up the dialog for you to choose Curtain Wall types to copy.
Message 8 of 8
ryan.wilsonUD3M5
in reply to: ToanDN
this doesn't work for me. still no storefront wall type... revit is the worst.
Forma Design Contest
