Nested generic annotation family in Title Block causing offset in pdf
se.ha
Advisor Advisor
Message 1 of 10
se.ha
Hi everyone,
I'm encountering an issue when exporting sheets to PDF in Revit. The problem is that the PDF is slightly larger than the actual sheet size. After investigating, I found that it seems to be caused by the nested generic annotation family.
I've already tried creating a completely new family, but the issue still persists. Has anyone else experienced this or have any ideas on how to fix it?
Thanks in advance!
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Replies (9)
Message 2 of 10
No issues here on my end. Maybe the issue is with your PDF Printer.
 https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-2019-print-t....
Message 3 of 10
se.ha
Hi @barthbradley
Thanks for your response.
I’m using the native PDF export in Revit 2024, so I don’t believe the issue is related to my PDF printer. The problem is actually visible within Revit itself. When I use "Zoom to Fit," the distance to the left and right borders is noticeably uneven.
Thanks again for your help!
se.ha
Message 4 of 10
azad.Nanva
I don't see any problem , use the zoom 100% :
Message 5 of 10
se.ha
Hi @azad.Nanva
The A4 Size is just an example. I need to export multiple sheet sizes at once. Thats why I am exporting with "Use sheet size" and not printing with a selected size. Fit to page or 100% Zoom doesn`t make a difference in this case.
se.ha
Message 6 of 10
azad.Nanva
Now I see what is your problem, this come from your generic annotation family :
Message 7 of 10
se.ha
I know. Thats what I said in my initial post:
But how do I fix this? I need my nested family to sit in the bottom right corner of the title block. I tried to move the label in the family, change its alignement, font size/type, ...
se.ha
Message 8 of 10
azad.Nanva
make invisible lines in the side of GenericAnnotation family ,I show you:
(view in My Videos)
my rectangle for see the all in the end was small but now your family work well. we have another solution with shared variable as width and height.this is fastest and simple way.
Message 9 of 10
se.ha
Thank you @azad.Nanva
I am not sure why, but the invisible lines actually work.
se.ha
Message 10 of 10
azad.Nanva
I am not sure too.but I think that is scale problem for G.A. family. by use the line you define the border and Revit corrects the mistake to recognizes the border of the family.
