I would like to create a component schedule but also would like to know what sheet(s) the particular component (in this case; piping) is located on. Is this possible in Revit? Thanks in advance!
it is not possible to directly include the sheet number as a field in a component schedule. You can create a custom project parameter, such as "Sheet Number," and apply it to the category of components you're interested in. Go to Manage > Project Parameters > Add. Name the parameter "Sheet Number," set it as a Text type, and assign it to the appropriate categories (e.g., Pipes).You'll need to manually enter the sheet number in this parameter for each component.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
You could Filter the Schedule By Sheet, but the thing is, Sheets only contain Views of the BIM Model and those Views may or may not capture the component you are scheduling.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-72859AB5-541B-4760-B3CE-15DA15124683
Thanks a lot for posting your question to the forums! Has the solution suggested by @vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
