Need to cut railing
5 REPLIES 5
spds.desk8
1294 Views, 5 Replies
Need to cut railing
i have tried to use void but its not working , need some help
5 REPLIES 5
mauricio_mssf
in reply to: spds.desk8
The tool don't do this funcion, is a specifc point don't waste you time, finish the railing before the local you want to cut, and make this finishing cut with a componet model in place family (or a loadable generic model) and get on with your life. You can use a regular railing for the top/bottom/posts but all the other stuff just do it manually.
In order not to interfere in the quantification, you can be part of the same grid, add a comment and filter the visualizations to not show.
Hide in views but not in the count.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Create it as a curtain wall and edit profile to change shape.
Toan Nguyen
ennujozlagam
not possible. try to change the position of your railing in the stair treads?
spds.desk8
in reply to: ToanDN
Completed using curtain wall
spds.desk8
in reply to: ennujozlagam
its not possible to change the design at this stage
Forma Design Contest
Technology Administrators
