Need Q&A sections to the learning tutorials offered by AutoDesk.
reese40m
reese40m
I'm not sure if I am putting this in the right section. My apologies if not.
I'd like to propose that AutoDesk add a Q&A section/forum in their learning resources so we can get answers when something like this happens. I've done many searches before posting this and have come up with nothing.
So I am a novice user of an educational version of REVIT 2023, and I started going thru the AutoDesk course for REVIT titled " 3D Modeling Foundations and Substructures". It was made using the 2021 version, so I am finding some of the information is out of date. In the 2nd section of the course, titled " Isolated foundations - Isolated foundation analysis properties." The instructions tell us to click on a button that, as far as I can figure out, no longer exists. It's a button in the "analysis tab - analytical model tools" panel called "check member supports." In fact, the analytical model's panel doesn't exist in my 2023 version. Then at the end of that module, it also tells us to click on the "Robot Structural Analysis" button. Which also doesn't exist.
Since REVIT software is not backward compatible it would be nice if AD would update the individual learning modules when they become obsolete like this one appears to be.
kimberly_fuhrman-jones
Hi, @reese40m ,
I apologize for the delay in responding. Our Revit tutorials page has changed and is updated with each release. You can find the tutorials for Revit 2024 here:
Help | Tutorials | Autodesk
Kimberly Fuhrman-Jones
Revit Community Manager
